Ungelesener Beitragvon Brausepaul » 17. Nov 2011, 08:45
So, also das Fahrzeug ist - entgegen meiner Behauptung weiter oben - ein 9N Polo 1.4 TDI Basis. Die PR-Codes kann man in einem der angehängten Bilder sehen. Auf planetvag.com finde ich dazu folgende Informationen:
PRCode: 0AQ = Front stabilizer
PRCode: 0G4 = Cable gearshift
PRCode: 0GG = Emission standard EU4
PRCode: 0Y1 = Standard climatic zones
PRCode: 0YA = Weight range 1 installation control only no requirement forecast
PRCode: 1AN = Anti-lock brake system (ABS)
PRCode: 1G2 = Steel spare wheel with original equipment tires
PRCode: 1JL = Rear shock absorption
PRCode: 1KD = Disc brakes rear
PRCode: 1LR = Front disc brakes with integrated adapter
PRCode: 1NC = Full wheel covers
PRCode: 2JF = Painted bumpers
PRCode: 2PQ = Steering wheel for air bag system
PRCode: 3S0 = Without roof rails/roof load rack
PRCode: 3U1 = Foldable trunk cover
PRCode: 4F1 = Central locking system
PRCode: 4R1 = Power windows
PRCode: 4UF = Driver's and front passenger air bag with front passenger air bag deactivation
PRCode: 4X1 = Side air bag front
PRCode: 5RQ = Right exterior mirror: convex
PRCode: 5SL = Left exterior mirror: aspherical
PRCode: 5TC = Without decorative inserts
PRCode: 8AY = Radio/navigation system
PRCode: 8GL = Alternator 120 A
PRCode: 8RE = 4 speakers (passive)
PRCode: B0X = Component parts set complying with vehicle type for Germany various parts
PRCode: BL3 = Special requirements Zimbabwe
PRCode: C0D = Steel wheels 5J x 14
PRCode: E0A = No special edition
PRCode: G0C = 5-speed manual transmission
PRCode: G10 = Front shock absorption
PRCode: H8P = Tires 165/70 R14 81T
PRCode: J0L = Battery 340 A (70 Ah)
PRCode: L06 = Suspension range 06 installation control only no requirement forecast
PRCode: M6F = 3-cyl. turbo diesel eng. 1.4 L/55 kW TDIpump-jet injection system base engine is T0U
PRCode: N4C = Fabric seat covering
PRCode: QG1 = Service interval prolongation
PRCode: T0U = 3-cylinder diesel engine 1.4 L unit 045.B
PRCode: X0A = National sales program Germany
Ich habe auch mal Bilder von dem Schlauch zwischen Karosserie und Türvorderseite sowie vom Türschloss gemacht. Ich kann da leider nicht identifizieren, was davon ein polfettwürdiger Kontakt ist und was nicht.
Stutzig macht mich BL3: Zimbabwe? Was ist das denn? Irgend etwas über die Innenbeleuchtung lese ich da jedenfalls nicht heraus.
