-50mm Federn
Verfasst: 26. Aug 2006, 20:04
von wilos
My name is Guillaume and I come from Belgium.
I have got a Polo 9n With BBS RX whells and Kw suspension(farkwerk) -35mm.
I think the rear of the car is a little to high and i have bought new arises(federn) -50mm only for the rear. 8)
Do you think it's a good idea? I can't tell you about the trade(mark) of the federn because i don't still have it.
Sorry for the language and thank you for you opinion. ;-)
Guillaume
Verfasst: 27. Aug 2006, 19:08
von wilos
No answer? :( :(
Verfasst: 27. Aug 2006, 22:02
von me1ssner
hello,
i think that nobody answered yet, because nobody knows the answer.
in my opinion: in germany it's not allowed to mix different arises. they are not optimized to fit together. And I wouldn't do it, because there could rise problems when driving (uncomfortable).
my english is even worser than yours :D...
Verfasst: 28. Aug 2006, 21:37
von wilos
hello,
Lol, thank you for your answer and i don't think my english is better than your ;-)
I have seen that a lot of people here, when they have got a kw var (1 or 2) do the same (35/50 or 40/60,....)
So, i think i will obtain the same result with new arises no?
nice evening ;-)
Verfasst: 28. Aug 2006, 21:42
von Maxmorritz
Salut wilos !!
Je n'ai pas tout compris ... tu peut me raconter sa en francais si tu veut bien ?!Q'as tu fait avec tes ressorts?
Merci
Verfasst: 28. Aug 2006, 21:50
von me1ssner
nice evening ;-)
but in that case are the front and back arises optimized for working together, because they are made by the same producer. in your case you want to use different arises from different producers.
but I am not a professional at this area... maybe somebody could write here something, with more know-how. I'm just writing what seems logical for me... got no proof for my opinion.
Verfasst: 28. Aug 2006, 22:38
von wilos
Salut wilos !!
Merci
Lol quelqu'un qui parle francais :cheesy:
Au fait, j'ai une Polo 9n rabaissée en Kw -35mm. J'en suis très content, tout est très bien sauf que j'aimerai qu'elle soit un peu plus basse de l'arrière (toutes les 9n ont du mal a redescendre à l'arrière) donc j'ai vainement cherché après des ressorts -50mm pour l'arrière que j'ai trouvés! Ca me fera donc une 9n en 35/50 ce qui me parait un bon compromis pour que l'avant ne soit pas plus haut..
Ce que je demandais c'est si certain l'ont déja fait et ce que ca donne niveau comportement,....
Verfasst: 28. Aug 2006, 22:56
von Maxmorritz
je ne connais personne qui a fait cela .... mais j'avais le meme probleme a ma voiture .je viens d'acheter les Bilstein filleter .. mai a l'arriere elle ne voulais pas descendre !!! Alors J'ai maintenant enlever caremmnent le filletage a l'arriere et juste mis les ressorts . Comme ca j'arrive au moins a mes 50 mm . Voila mon histoire.
mais comme tu dis .. ce n'est pas facile de descendre une polo 9n a l'arriere !!!
Verfasst: 29. Aug 2006, 09:51
von wilos
Bien les ressorts je les ai achetés chez un tunner à charleroi qui les commande en Allemagne car effectivement je n'ai trouvé personne qui faisait ca...
J verrai bien mais je pense que ca devrai bien aller non? t'es en - combien à l'avant?
Verfasst: 29. Aug 2006, 20:40
von Maxmorritz
A ta place je mettrais la meme marque comme a l'avant ... Moi je suis maintenant a des vrais 40mm l 'avant.
Verfasst: 30. Aug 2006, 11:16
von wilos
Oui j'ai voulu faire ca mais KW ne vend pas plus de -35 en ressorts...
En plus à l'avant je suis quand même bien bas (au moins réelement -35).
T'as une photo de ton auto par hasard?
