MFD3 RN510 on VW polo 9n3 my2006
nasa24
Ungelesener Beitragvon nasa24 » 10. Mai 2012, 05:01
Hello, I want to install a mfd3 rns510 on my vw polo 9n3. I do not know where to start, I only know that I need a cable canbus 2.0/1.6. I would also like to know if you can use the controls on the steering wheel (steering wheel scirocco'09) and if my mfa (tacho / fis) contains information navigation radio etc..
There are guides in the forum to be able to install and activate all the features this radio? can you give to all the links necessary to buy the components except the radio? can you tell me which version of my radio to take pole or are good all versions (ABCD)?
Nilz
Re: MFD3 RN510 on VW polo 9n3 my2006
Ungelesener Beitragvon Nilz » 10. Mai 2012, 14:56
The RNS510 doesn't fit into your 9N3
Baby-Polo
Ungelesener Beitragvon Baby-Polo » 10. Mai 2012, 19:30
you can make it run... you have to edit the 'mittelkonsole' and have to buy a adapter. with the 'MFA' all functions will be shown...
on canshack.de you have to buy the 1.6 on 2.0 adapter for rns
http://www.canshack.de/german/can-bus-m ... uster.html
nasa24
Ungelesener Beitragvon nasa24 » 11. Mai 2012, 00:00
Thank you for answers regarding tv bluetooth gps you know that other cables you need? I would like to use the radio to the full performance of its functions.
last question .... is there to activate something from vag?
I have tried but I could not find anything, there is a topic where it talks about this work after I take cues to assist in processing?
Thank you for answers and sorry for too many questions.
edit..
Sorry you know if my my2006 gotta take a specific version of rns or go all well for the purposes of the work.
Baby-Polo
Ungelesener Beitragvon Baby-Polo » 11. Mai 2012, 09:20
you have to install a gps signal, that's all. All another signals are on you original radio system.
You can't check the rns in your car with vag.com or something and you don't have to make a diagnose.
If you need more information, i have to write in German:)
nasa24
Ungelesener Beitragvon nasa24 » 11. Mai 2012, 16:40
thanks for reply. can safely speak German, I use a translator. ok then gps antenna (the antenna gol5 okay?), cable mentioned above. for TV and Bluetooth you know what and where you need to buy?
