Airbag - (Dringend)
Verfasst: 20. Sep 2010, 13:27
von polo38
Hallo ,
I registered your forum 5 minutes ago.This forum is wonderful.I can't speak German very well.
I want to ask a question. I have 2004 Polo 9n . I bought a 3-speichen steering wheel whose steering wheel Polo 9n3 with airbag . Can we install this steering wheel to my polo 9n? !!!! Could there be a socket and PIN problem?
My car is :
My car's interior view :
There is the steering wheel what I want to install to my car.
Re: Airbag - (Dringend)
Verfasst: 20. Sep 2010, 14:33
von polo38
Please help me
I will buy it tonight. It is a bit expensive.
Verfasst: 20. Sep 2010, 15:07
von Gast
what can i do for you ?
Verfasst: 20. Sep 2010, 15:21
von r3g1m
Will there be a socket and PIN problem?
Verfasst: 20. Sep 2010, 15:41
von polo38
Yes , you can help me if you know exchanging the parts. Can there be any problems before and and after this changing.
Nobody knows something about this issue in Turkey.
Verfasst: 20. Sep 2010, 16:56
von Nico84
No
Verfasst: 20. Sep 2010, 20:25
von polo38
Thank you very much for your answer. I hesitated about airbag and socket.
This is the steering wheel which I want to buy.In fact it is jetta tour steering wheel.
Verfasst: 20. Sep 2010, 20:45
von polo38
I will cancel buttons .
This is my steering wheel now:
http://cgi.ebay.de/Polo-9n-Lenkrad-/270 ... 3f0322d5a7
Verfasst: 21. Sep 2010, 01:00
von polo38
I found a source. A person did my operation
http://blog.dermk4vw.com/archives/784-M ... lo-9N.html
I ask a questions about socket and kabel.Are all airbags number of cabel the same?
For instance , from 9N 's airbag there is 3 kabel connection on airbag , also 9N3's airbag there is 3 kabel connection on airbag.
Can we say this?
Verfasst: 21. Sep 2010, 08:05
von Gast
Hi !
Maybe this could help you ...
http://www.polo9n.info/anleitung-122.html
Greetings, Christian.
Verfasst: 23. Sep 2010, 22:05
von polo38
My steering steel was come in the morning.
When I look the airbag socket which enter the airbag, two cable enter the socket.
Can I use my old socket for this airbag?The sockets which are enter the airbag are same.
Slip rings are completely same.
Verfasst: 23. Sep 2010, 23:47
von copy
Achtung vor der De/ Montage des AIRBAGS Batterie abklemmen.
kes akü kablosunun HAVA YASTIKLARI montajı Saygı.
Attetion before work at the Airbag disconnect battery!!!
it may be a problem to use the buttons on the new wheel.
Verfasst: 23. Sep 2010, 23:52
von polo38
I will disconnect them and I will sell
:D
Airbag sockets are same I see.
Thank you a lot.
Can the airbags characteristics be different?
Verfasst: 28. Sep 2010, 21:42
von polo38
Does anybody knows about it?
