Mfd1 fis ibiza 6l dashboard polo 9n3 fis
Hey. I have a ibiza cupra tdi 6l 2007, I have installed the browser MFD1 ref 1M0 035 191 B, and I have mounted instrument panel with fiscal polo 9N3 ref 6q0920843B , I turn on the browser box directions and information of radio in the dashboard, would be possible? I should do? greetings and thanks.
Re: Mfd1 fis ibiza 6l dashboard polo 9n3 fis
As far as I know you need a MFD index "G" and the TMC receiver box to display the information in the Polo 9N FIS
mir doch wurscht!
VW Golf 1 Cabrio
Hello, my MFD1 is 1M0 035 191 B and my dashboard 6q0920843B, with me only official tmc? that reference has to be the TMC? , And tried to get me to vagcom the channel 017 of the frame, and when I add +16 in the coding to activate the fis, I was not active.
The MFD has to be xxx xxx xxx G (I think C & D could be flashed to G, but no warranty). To communicate with the dashboard you need an extra controller (the TMC-Box for receiving traffic information, e.g. 1J0 919 894 A) which is able to convert the signal from the MFD to the dashboard.
Also.. the MFD "B" seems to be a very old version, and "non-DX", so there are no actual data CDs available since ~2007
mir doch wurscht!
VW Golf 1 Cabrio
Hi, thanks for answering my MFD1 is a reference: 1M0 035 191 B, and if the dynamic is like this link:
http://www.dndservices.co.uk/Seat-Dynam ... 01034.html
Therefore putting a TMC should work for me properly by plugging the fiscal? Or what else I have to do?
I also tried to encode the channel 017 by adding 016 to the original coding, to enable the FIS of the table (as I have a 2007 Ibiza Cupra TDI 6l) and the dashboard and mounted on my car is a VW Polo 9N3 tdi 2007 , and will not let me add 016 to the original coding, I have to do?
Helpme please !
No need to code (+16) by connection CAN ... only for 3LB (not in Polo available)I also tried to encode the channel 017 by adding 016 to the original coding, to enable the FIS of the table (as I have a 2007 Ibiza Cupra TDI 6l) and the dashboard and mounted on my car is a VW Polo 9N3 tdi 2007 , and will not let me add 016 to the original coding, I have to do?
verstorben am: 26.03.2016
Polo 9N Cricket
Hello potatodog, then to be encoded, to loosen my seat ibiza 6l (with panel instruments with fisl polo 9N36q0920843B ) fis the browser mfd1 ? 1M0 035 191 B in fis instruments panel thanks.
Help me please ! installed tmc 3B0 919 895 A and installed correct , and does not work, and plugged the connector box tmc instruments can h can l, and l can tmc to h can MFD1 the siemens connector, but I get the on the fiscal, not if I'm missing something or you have to activate something.
Helpme please !
mir doch wurscht!
VW Golf 1 Cabrio
I also tested with a browser XXX XXX XXX G and either I get the info! have if you can help me, not whether to do something else! I did this -> http://www.pimpowski.de/images/lolek/Na ... %20TMC.pdf
Hello, and gotten it to work with a nevegador of MFD1 VW 3B0 035 191 G and my TMC, but my seat MFD1 of 1M0 035 191 B does not work, I can update it or do something to make it work?
