Mfd1 fis ibiza 6l dashboard polo 9n3 fis
Verfasst: 28. Mai 2012, 23:31
von r0b3r
Hey. I have a ibiza cupra tdi 6l 2007, I have installed the browser MFD1 ref 1M0 035 191 B, and I have mounted instrument panel with fiscal polo 9N3 ref 6q0920843B , I turn on the browser box directions and information of radio in the dashboard, would be possible? I should do? greetings and thanks.
Re: Mfd1 fis ibiza 6l dashboard polo 9n3 fis
Verfasst: 28. Mai 2012, 23:39
von chriSpe
As far as I know you need a MFD index "G" and the TMC receiver box to display the information in the Polo 9N FIS
Verfasst: 29. Mai 2012, 08:12
von r0b3r
Hello, my MFD1 is 1M0 035 191 B and my dashboard 6q0920843B, with me only official tmc? that reference has to be the TMC? , And tried to get me to vagcom the channel 017 of the frame, and when I add +16 in the coding to activate the fis, I was not active.
Verfasst: 29. Mai 2012, 11:24
von chriSpe
The MFD has to be xxx xxx xxx G (I think C & D could be flashed to G, but no warranty). To communicate with the dashboard you need an extra controller (the TMC-Box for receiving traffic information, e.g. 1J0 919 894 A) which is able to convert the signal from the MFD to the dashboard.
Also.. the MFD "B" seems to be a very old version, and "non-DX", so there are no actual data CDs available since ~2007
Verfasst: 29. Mai 2012, 21:57
von r0b3r
Hi, thanks for answering my MFD1 is a reference: 1M0 035 191 B, and if the dynamic is like this link:
http://www.dndservices.co.uk/Seat-Dynam ... 01034.html
Therefore putting a TMC should work for me properly by plugging the fiscal? Or what else I have to do?
I also tried to encode the channel 017 by adding 016 to the original coding, to enable the FIS of the table (as I have a 2007 Ibiza Cupra TDI 6l) and the dashboard and mounted on my car is a VW Polo 9N3 tdi 2007 , and will not let me add 016 to the original coding, I have to do?
Verfasst: 2. Jun 2012, 09:00
von r0b3r
Helpme please !
Verfasst: 2. Jun 2012, 09:22
von potatodog
No need to code (+16) by connection CAN ... only for 3LB (not in Polo available)
Verfasst: 2. Jun 2012, 15:56
von r0b3r
Hello potatodog, then to be encoded, to loosen my seat ibiza 6l (with panel instruments with fisl polo 9N36q0920843B ) fis the browser mfd1 ? 1M0 035 191 B in fis instruments panel thanks.
Verfasst: 16. Jun 2012, 16:17
von r0b3r
Help me please ! installed tmc 3B0 919 895 A and installed correct , and does not work, and plugged the connector box tmc instruments can h can l, and l can tmc to h can MFD1 the siemens connector, but I get the on the fiscal, not if I'm missing something or you have to activate something.
Verfasst: 18. Jun 2012, 08:01
von r0b3r
Helpme please !
Verfasst: 18. Jun 2012, 19:57
von chriSpe
Verfasst: 18. Jun 2012, 23:12
von r0b3r
I also tested with a browser XXX XXX XXX G and either I get the info! have if you can help me, not whether to do something else! I did this ->
http://www.pimpowski.de/images/lolek/Na ... %20TMC.pdf
Verfasst: 20. Jun 2012, 00:11
von r0b3r
Hello, and gotten it to work with a nevegador of MFD1 VW 3B0 035 191 G and my TMC, but my seat MFD1 of 1M0 035 191 B does not work, I can update it or do something to make it work?
Verfasst: 23. Jun 2012, 10:15
von r0b3r
Helpme
