Does anybody know much about this engine?
DKSA
Ungelesener Beitragvon DKSA » 1. Jul 2011, 02:03
Hi all!
i have a 9n3 polo hatch, which in South Africa comes with a EA-111 BAH/BGU 1.6 8v motor. It uses a roller rocker camshaft (RSH).
Power: 74kw(100hp) @5500rpm
Torque: 140nm(103lb/ft) @3250rpm
the specs are as follows:
-Engine: EA-111 BAH/BGU
-multi-point electronic fuel injection
-ECU: Bosch ME7
-Displacement: 1598cc/97.5 cubic inches
-SOHC 2 valves per cylinder
-Rev Limit = 6500rpm
-Compression ratio: 10:1
-Bore: 76.5mm
-Stroke: 86.9mm
-Throttle body is electronic drive by wire
-Intake port = 28mm
-Intake valve diameter = 32.5mm
-Exhaust port = 25mm
-Exhaust valve diameter = 25.5mm - 26mm
does anyone know much about this motor or have any expereince with it?
notranked
Re: Does anybody know much about this engine?
Ungelesener Beitragvon notranked » 2. Jul 2011, 18:12
Are you sure, that this engine has 8 valves?
I found only the 1.6 engine with 16valves and 105hp.
TMT
Ungelesener Beitragvon TMT » 2. Jul 2011, 19:18
I know this engine from the Golf Mk 4. There it is called 1.6 SR. The 16 Valves 1.6 litre Engine you mean is a newer one.
Fahrzeuge: Volkswagen The Beetle
DKSA
Ungelesener Beitragvon DKSA » 2. Jul 2011, 23:41
ye positive it is 8v - it is in my car :haha:
some more info
-Intake port = 28mm
i am wanting to tune the motor to get 130hp (standard 100hp)
DKSA
Ungelesener Beitragvon DKSA » 3. Jul 2011, 00:11
The SR engine looks different! my car, the engine cover is also the airbox
DKSA
Ungelesener Beitragvon DKSA » 3. Jul 2011, 01:08
chriSpe
Ungelesener Beitragvon chriSpe » 3. Jul 2011, 17:47
I think the Golf V ( + Touran / Caddy) has also this engine:
http://www.doppel-wobber.de/wbb2/Inform ... toren.html
The engine is not used for Polos in Europe, there an engine with 16 valves is used ('BTS'), also based on the EA111 block, but with a timing chain and single ignition coils
mir doch wurscht!
Fahrzeuge: VW Golf 1 Cabrio
