9n 130ps tdi optimierung
Ungelesener Beitragvon Gast » 26. Jan 2006, 14:43
@decat
is 130 HP TDI clutch of max 380 Nm aushalten(Spitzenwerte). Since these data in the quantity production only rarely I on a number more surely would rather go. Therefore B&B is simply equipped with too much torque. HOPA does not make for you 350 Nm with those my personal clutch already fought hat(gab on fair trading ne neue)... therefore takes rather an increase those as high-gone as some tuner versprechen(380 Nm or 410 Nm)....der Ibiza Cupra has also only 320 Nm and the Topsport Leon also 320Nm... that is not without reason like that, because nevertheless one could rausholen from the Cupra calmly more than 320 Nm, but no clutch the standard gives to be blocked more made than the 1,9er clutches those, and there the tolerances in the manufacturing ziwschen A u B commodity are apparent wurscht, come it stop before times ne b-clutch are also often blocked... by the way: N of acquaintance works at Bosch in the examination of the PD elements, which means: each 10. PD element is taken by the volume and examined, with this examination does not reach up to 50% of the PD elements not their max. Injection pressure....jetzt considers you times how many by us with b-commodity nozzles is equipped! And so similarly also have an interview I with the clutches. By 130 HP should be examined the Diesel all, but who knows that already!
fabiano
Ungelesener Beitragvon fabiano » 26. Jan 2006, 14:48
hammer english
ich schmeiss mich weg :betthops:
FABIA GT 2.0 Cupra R luftführung,Kenwood KVT 7-25DVD,Audi s-line 8x18,yokohama Parada Spec2 215/35ZR18,KW Gewinde var2 ca 60mm tiefer.Foliatek Midnight Reflex2.milotek grill,blenden und Rückleuchten .Bastuck 63mm V2A anlage ab Kat mit 2x70 rohren. 312mm Bremsanlage vom S3/RS, Motor überarbeitet, ...
http://www.polo9n.info/gastfahrzeug-133.html
Fahrzeuge: Skoda 6Y Fabia
Ungelesener Beitragvon Gast » 26. Jan 2006, 14:49
hammer das übersetzungsprogramm!!!!!!!!!
px
Ungelesener Beitragvon px » 26. Jan 2006, 14:56
Echt, ich glaub da kommt er mit dem deutschen weiter :lol:
fabiano
Ungelesener Beitragvon fabiano » 26. Jan 2006, 15:05
@ulf
7,4 kg / PS und?
soviel hatte mein g40 Original.
das ist ja wie ein 1200 kg schweres auto mit 160 ps . also nichts dickes.
XS
Ungelesener Beitragvon XS » 26. Jan 2006, 15:09
was war das denn für ein Übersetzungsprogramm?
Babelfisch? :lol:
px
Ungelesener Beitragvon px » 26. Jan 2006, 15:11
Er hat doch auch 160 PS ;) :D
Ungelesener Beitragvon Gast » 26. Jan 2006, 15:13
@px
wie jetzt,eindeutige antwort
px
Ungelesener Beitragvon px » 26. Jan 2006, 15:16
Ulf -> 130 PS Basis -> gechippt auf 160 PS
Ich hab deinen Vergleich daher nicht so wirklich verstanden ;) Hochgerechnet entspricht seine Wagen genau dem, es ist ein 1200kg schweres Auto mit 160 PS :D
fabiano
Ungelesener Beitragvon fabiano » 26. Jan 2006, 15:23
weil ich dachte er wollte einen auf wenig gewicht und viel leistung machen.
also mein Fabia wiegt mit dem großen 2.0 und max. austattung immernoch 70 kg weniger .
und der polo ist ja auf der Fabia Basis gebaut .
Zuletzt geändert von fabiano am 26. Jan 2006, 15:33, insgesamt 1-mal geändert.
px
Ungelesener Beitragvon px » 26. Jan 2006, 15:30
Ja gut, wiegen viele Wagen grundsätzlich weniger als der Polo, kann man nicht vergleichen. Die meisten stört das ja auch nicht, das ist ja kein Baufehler etc. sondern die Verwendung von mehr oder schwererem Material usw. Ob da dann noch ein Klimakompressor drauf kommt... naja, andere setzen eben andere Prioritäten.
Fabolous
Ungelesener Beitragvon Fabolous » 26. Jan 2006, 15:53
Wenn Du eine Fabia Limousine 2.ol mit "max.Ausstattung" hast nehme ich an das sich Dein Fzg.gewicht bei ~1.200kg bewegt [laut Skoda.de Datenblatt].
Ulf hat rechnerische ~1.184kg nach seinen Angaben.
Ich seh da keine 70kg weniger auf Deiner Seite... Erklär doch mal.
i Bild haters.
fabiano
Ungelesener Beitragvon fabiano » 26. Jan 2006, 16:00
du kennst doch bestimmt diese wiege station vom zoll .
fahr mal rauf und lasse dich überraschen.
und mein beifahrer hat drin gesesen.
Fabolous
Ungelesener Beitragvon Fabolous » 26. Jan 2006, 16:07
Das würde ja bedeuten das Skoda Datenblatt des 2.ol Fabia "lügt"... :rolleyes:
i Bild haters.
Ungelesener Beitragvon Gast » 26. Jan 2006, 16:08
vielleicht war sein tank leer und saß nicht drin,denn würde es hinkommen!!
px
Ungelesener Beitragvon px » 26. Jan 2006, 16:09
Dein Avatar sieht gar nicht so nach Stripping-Fan aus *g* Sooo billige Materialien werden die doch auch im Skoda nicht verwenden, dass er dann soviel leichter ist als Ulf-Polo-Gerüst? :D
Fabolous
Ungelesener Beitragvon Fabolous » 26. Jan 2006, 16:12
Das seh ich genauso, evtl. liegt es an der heissen Luft... :D
i Bild haters.
ulf
Ungelesener Beitragvon ulf » 26. Jan 2006, 16:23
7,4 kg / PS und?
Tja, aber aus welcher Zeit stammt Dein G 40?
7,4 kg / PS in nem Diesel-Kleinwagen Baujahr 2004 findet man nicht an jeder Straßenecke.
Hast Du den 85kW -Motor im Fabia?
Dann berechne doch mal Dein "zeitgenössisches" Leistungsgewicht . . . :D
Gruß Ulf
Mein Polo
Fahrzeuge: Polo 6R WRC
Fabolous
Ungelesener Beitragvon Fabolous » 26. Jan 2006, 16:28
Hör auf, Ulf. Ich musste schon bei den 170Nm lachen... :D
i Bild haters.
Ungelesener Beitragvon Gast » 26. Jan 2006, 16:38
...Ich musste schon bei den 170Nm lachen... :D
trotzdem hat schon mehr als 100 ps diesel glatt gemacht!!!!(ich saß mit drin)
Mitglieder in diesem Forum: Bing [Bot] und 1 Gast
