Angel eyes
English, Italian, Spanish, Turkish... everyone is very welcome!
Join us!
gigas19
Angel eyes
Ungelesener Beitragvon gigas19 » 27. Apr 2007, 20:22
Can anyone tell me how can i adjust light beam at angel eyes...i want to raise it...i think i have to do it manualy because they dont have any motor...how can it be done...
thanks
gigas19
Ungelesener Beitragvon gigas19 » 27. Apr 2007, 22:27
gullidriver
Ungelesener Beitragvon gullidriver » 27. Apr 2007, 22:50
i do`nt know it exact but , i think u must use the motor from the Original light !
gigas19
Ungelesener Beitragvon gigas19 » 27. Apr 2007, 22:53
Angel eyes dont have the "rotator" for the motor to regulate the beam...
gullidriver
Ungelesener Beitragvon gullidriver » 27. Apr 2007, 22:58
Sorry . i havnt work with Angel Eys yet !
what u mean with ROTATOR ?
gigas19
Ungelesener Beitragvon gigas19 » 27. Apr 2007, 23:06
the part which adjust beam...operated by motor...like motor is a screwdriver and rotator is a bolt :D
gullidriver
Ungelesener Beitragvon gullidriver » 27. Apr 2007, 23:50
good idea ;-)
Sylonien
Ungelesener Beitragvon Sylonien » 28. Apr 2007, 02:00
You should just use the standard Polo's headlight motor, or don't you have the original headlights anymore?
Anyway, there are two white plastic screws on top of each Angel headlight that you can just turn with a hex type screw driver - that will level the full beam and the normal dipped headlights. ;)
gigas19
Ungelesener Beitragvon gigas19 » 28. Apr 2007, 10:58
2 bolts? shouldnt there be just one for heightness?Yes i have orginaln motor but like i said i didnt see any "rotator" for the motor like in originilan headlamps...does any1 have a motor in angel eyes?
gigas19
Ungelesener Beitragvon gigas19 » 28. Apr 2007, 11:22
Ok, i regulated the height with "Gedora"..tnks for you help...last question does orign motor fits in angel eyes to control them electronically?
px
Ungelesener Beitragvon px » 28. Apr 2007, 11:52
They should fit. At least you have to control them electronically in Germany ;)
gigas19
Ungelesener Beitragvon gigas19 » 28. Apr 2007, 12:34
But where do you put the motor in... some photos of backside of the AE would be great...
Sylonien
Ungelesener Beitragvon Sylonien » 29. Apr 2007, 01:45
Yes there are two screws cause you can change the height for the full beam and the dipped headlights.
Yes the original motors do fit cause I have them in mine!!!! :D
You have to remove the FK black plastic screw inside the smaller round headlamp.
RED ARROWS - change the height.
YELLOW ARROW - remove that black plastic thing. Just turn it left or right and it'll click then you can take it out. Do the same with your original VW ones and put it inside the FK headlamp and twist it into place - CLICK and done :)
gigas19
Ungelesener Beitragvon gigas19 » 3. Mai 2007, 21:57
Thanks for the pictures..i really apreciate this...could you tell me why are there two screws for hightness?
Its very hard to regulate the hightness if the lights are not in fixedd position...but if they are i cant reach the bolts...
Sylonien
Ungelesener Beitragvon Sylonien » 3. Mai 2007, 23:21
You can adjust the height because its Polo's different for things like tyre, weight and wheel and stuff like that which will adjust the angle of the light beam. So you can adjust the height of the lightbeam.
You can change the height once its fixed in to position. The two white plastic bolts are still reachable from the top when you open the bonnet. ;)
gigas19
Ungelesener Beitragvon gigas19 » 10. Mai 2007, 22:55
is it possible to replace broken bulb in angel eyes "ring" around the headlamp?last two bulbs are damaged....
Sylonien
Ungelesener Beitragvon Sylonien » 10. Mai 2007, 23:47
Yes you can and PM'd you.
gigas19
Ungelesener Beitragvon gigas19 » 12. Mai 2007, 17:27
Me again...:)
Does any1 know what type of bulbs are in angel eyes rings(not main light but the bulbs in the rings)
