Front suspension problem
branislav89
Ungelesener Beitragvon branislav89 » 31. Jan 2012, 23:11
Greetings from Serbia!
My name is Branislav. I drive 9n3 1.9 TDI 74kW. Few days ago i went to a service to adjust steereng problems. When it was attached on the instruments, right front wheel showed caster angle: -1 deg 24" 8O . The correct value would be: -0 deg 24". What should i do? Does someone know what needs to be replaced in order to have correct front wheel geometry?
For now, the biggest problem, that i know of, is the tire wear. Anything else, is it possible?
Thank you all for answers and suggestions.
