Hi all.
I’m owner of SEAT IBIZA CUPRA TDI 6L MY’2007.
I have just retrofitted a VW POLO 9n3 TDI 130cv Dashboard with FIS. All looks fine except the ABS Indicator light is ON and the oil level sensor is active and my car don’t got it
Dashboard ref : 6q0920843B
Address 03: ABS Brakes Labels: 6R0-907-37x-ESP.lbl
Control Module Part Number: 6Q0 907 379 AS HW: 6Q0 907 379 AS
Component and/or Version: ESP 8.0 front H05 0003
Software Coding: 0002238
Work Shop Code: WSC 03661 758 00200
3 Faults Found:
18055 - Check Coding of ECUs on Powertrain Data Bus
P1647 - 000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 75
Mileage: 37015 km
Time Indication: 0
01314 - Engine Control Module
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 115
Mileage: 37015 km
Time Indication: 0
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 115
Mileage: 37015 km
Time Indication: 0
01318 - Control module for injection pum ( J399)
000 Intermittent
The problem i think is that i got a wrong coding on my ABS unit. (The ESP and ABS dont Works)
If i plug my original Dashboard all Works fine and no failure is registered on the units.
I think that i need to slove this problem is a coding of a original VW Polo 9n3 with FIS. ABS and dashboard
Can help me? I dont know what more to do
Regards from Spain
rober
Kombiinstrument fis seat ibiza 6l polo 9n3 problem
Tacho, MFA, FIS, etc.
