Coding ABS/ESP/Tire pressure
zeburp
Ungelesener Beitragvon zeburp » 25. Feb 2016, 19:54
Hello,
I retrofited ESP to my Polo, at oem I got ABS and tire pressure. ( A + R )
So I installed an module E + R .
6Q0 907 379 AT
6Q0 614 517 AL
All is wired and connected to G85 + G419 . G85 adaptation is Ok too !
But all ESP/ABS light is on and I get this error on VCDS:
01315 - Transmission Control Module: Aucun Communications
Like the module is coded for Automatic transmission.
My softcoding is 0000502
Workshop code is 00788
Someone have this module and can give me your soft coding ?
Or something else to do ?
Thanks
zeburp
Ungelesener Beitragvon zeburp » 26. Feb 2016, 12:40
Hello,
So i talked with Dieselaktivist, he give 3 different coding 0000296 0000320 and 0000365.
Always same error code with 296 and 320.
But now with 365:
I have:
18055 - Check Coding of ECUs on Powertrain Data Bus
01317 - Control Module in Instrument Cluster
I got an GTI Tcaho FIS from potatodog.
So i tried with my old original tacho, same problem.
zeburp
Ungelesener Beitragvon zeburp » 29. Feb 2016, 15:12
Hello,
So i finally found teh right code for my unit: 2371
I found lot of information about ESP 8.0 coding unit, I copy what i found un der sto help someone maybe:
Code WSC
6Q0 907 379 AQ ESP 8.0 front H04 0002 0002338 06402
6Q0 907 379 AH ESP 8.0 front H03 0001 0000305 31414
6Q0 907 379 T ESP 8.0 front H03 0002 0000368 31414
6Q0 907 379 T ESP 8.0 front H03 0002 0000305 00788
6Q0 907 379 T ESP 8.0 front H03 0002 0000314 31414
6Q0 907 379 AH ESP 8.0 front H03 0001 0000305 00788
6Q0 907 379 AQ ESP 8.0 front H04 0002 0002353 31414
6Q0 907 379 AH ESP 8.0 front H03 0001 0000320 31414
6Q0 907 379 T ESP 8.0 front H03 0002 0000314 00788
6Q0 907 379 AT ESP 8.0 front H03 0003 0000320 00788
6Q0 907 379 AS ESP 8.0 front H05 0003 0002368 00788
6Q0 907 379 AS ESP 8.0 front H05 0003 0002371 00788
6Q0 907 379 T ESP 8.0 front H03 0002 0000431 13765
6Q0 907 379 AQ ESP 8.0 front H04 0002 0000365 13765
6Q0 907 379 AH ESP 8.0 front H04 0001 0000428 13765
6Q0 907 379 AS ESP 8.0 front H05 0003 0000365 13765
6Q0 907 379 AS ESP 8.0 front H05 0003 0000437 13765
6Q0 907 379 AF - Coding: 0002061 or 0002079 or 0002082 or 0002085 or 0002103 or 0002115 or 0002118 or 0002122 or 0002136 or 0002145 or 0002175 or 0002181 or 0002190 or 0002193 or 0002199 or 0002202
As can be seen above, AF suffix has the whole gamut of codings and each should be tried before throwing in the towel.
6Q0 907 379 AG - Coding: 0002202 or 0002229 or 0002238
6Q0 907 379 AH - Coding: 0000299 or 0000284
6Q0 907 379 AQ - Coding: 0002356
6Q0 907 379 AS - Coding: 0002347 or 0002368 or 0002368 or 0002491
6Q0 907 379 AT - Coding: 0000269
6Q0 907 379 BC - Coding: 0002136 or 0002098
6Q0 907 379 C - Coding: 00044
6Q0 907 379 D - Coding: 00124 or 00188
6Q0 907 379 E - Coding: 0001097
6Q0 907 379 G - Coding: 00044 or 00045
6Q0 907 379 H - Coding: 00188
6Q0 907 379 L - Coding: 0001097
6Q0 907 379 M - Coding: 0000000
6Q0 907 379 R - Coding: 0000008
6Q0 907 379 T - Coding: 0000281 or 0000296 or 0000299
6Q0907379AS ESP 14" FS-III Drum brake 0000422
6Q0907379AS ESP 14" FS-III Drum brake 0000428
6Q0907379AS ESP 14" FS-III Drum brake 0000440
6Q0907379AS ESP 14" FS-III Disc brake 0000329
6Q0907379AS ESP 15" C54 Disc brake 0000275
6Q0907379AS ESP 14" FS-III Drum brake 0000434
6Q0907379AS ESP 14" FS-III Drum brake 0000431
6Q0907379AS ESP 14" FS-III Drum brake 0000437
6Q0907379AS ESP 14" FS-III Drum brake 0000470
6Q0907379AS ESP 14" FS-III Disc brake 0000365
6Q0907379AS ESP 15" C54 Disc brake 0000296
Dieselaktivist
Ungelesener Beitragvon Dieselaktivist » 29. Feb 2016, 17:14
great writeup there! Glad I could provide some help in the right direction. Did you yet manage to adapt the system and the steering angle so it works completely?
zeburp
Ungelesener Beitragvon zeburp » 1. Mär 2016, 10:46
Yea you help me a lot ;). Thanks.
I just did the G85 calibration, with 40168 acces code.
After full testing, I loss Tire pressure with 2371 but ESP/ABS work fine.
After looking the coding, when coding is 4 number, that disable Tire pressure.
I will testing coding with H03 unit to see if I get different reaction.
xingping
Ungelesener Beitragvon xingping » 10. Mär 2020, 16:00
Hello, have you finally found the right code?
