I need a advised..
English, Italian, Spanish, Turkish... everyone is very welcome!
Join us!
VoL
I need a advised..
Ungelesener Beitragvon VoL » 1. Jun 2007, 19:16
I must mount this rings...
What tipe of glue you advise me to use?
an liquid glue?
Fahrzeuge: Polo 9N Trendline
Ungelesener Beitragvon Gast » 1. Jun 2007, 22:49
Erm, I am not sure, but I think that those rings do not need any glue to be mounted. Have you tried to mount them without glue?
VoL
Ungelesener Beitragvon VoL » 2. Jun 2007, 00:31
Yes, it didn't stay. It fall down when you touch, or an minimal vibration.
(thank you so much for the help ;))
Sylonien
Ungelesener Beitragvon Sylonien » 2. Jun 2007, 05:02
Well then use superglue I guess or anytype will do - but I would recommend something strong cause the ring is so thin so the only contact point will need to be very strong incase it falls down easily when you use those knobs.
4Snake
Ungelesener Beitragvon 4Snake » 2. Jun 2007, 08:35
DON`T USE SUPERGLUE WHICH CONTAINS CYANCRYLATE !!!!
If you use it you can put your board to the waste, the glue is blowing out and the black area around the knobs will become a milky touch, it is not possible to use this glue, i tried in the past and had a bad surprise.
Better you use a 2 component Epoxy glue, that will not blow out and it sticks hardly after 2 hours.
best regards
Sylonien
Ungelesener Beitragvon Sylonien » 3. Jun 2007, 04:16
^ Well there you go - a good proper advice. ;)
VoL
Ungelesener Beitragvon VoL » 3. Jun 2007, 10:04
I post some photos at the work ultimated! ;)
