Hi all.
I’m owner of SEAT IBIZA CUPRA TDI 6L MY’2007.
I have just retrofitted a VW POLO 9n3 TDI 130cv Dashboard with FIS. All looks fine except the ABS Indicator light is ON and the oil level sensor is active and my car don’t got it
Address 03: ABS Brakes Labels: 6R0-907-37x-ESP.lbl
Control Module Part Number: 6Q0 907 379 AS HW: 6Q0 907 379 AS
Component and/or Version: ESP 8.0 front H05 0003
Software Coding: 0002238
Work Shop Code: WSC 03661 758 00200
3 Faults Found:
18055 - Check Coding of ECUs on Powertrain Data Bus
P1647 - 000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 75
Mileage: 37015 km
Time Indication: 0
01314 - Engine Control Module
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 115
Mileage: 37015 km
Time Indication: 0
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 115
Mileage: 37015 km
Time Indication: 0
01318 - Control module for injection pum ( J399)
000 Intermittent
The problem i think is that i got a wrong coding on my ABS unit. (The ESP and ABS dont Works)
If i plug my original Dashboard all Works fine and no failure is registered on the units.
I think that i need to slove this problem is a coding of a original VW Polo 9n3 with FIS. ABS and dashboard
Can help me? I dont know what more to do
Regards from Spain
rober
Abs/esp Polo 9n3 coding tdi fis
Tacho, MFA, FIS, etc.
Zuletzt geändert von r0b3r am 16. Jan 2012, 13:04, insgesamt 1-mal geändert.
Re: Abs/esp Polo 9n3 coding tdi fis
Hello. I do not have right to send a mail, for being still too new, my email is rober1989_Cs@hotmail.com, if you can ponte in contact with me to solve it please, since I am not able of which it works neither the ESP nor abs to me.
Airbag works correct
Car is Seat ibiza cupra 6l tdi 2007 1.9 Tdi 160cv
If it does not bother leaves your msn to you I add and you to speak. If somebody can help agradeceria me.
The only guy, in this forum, who could help you ist: potatodog.
You have 2 options:
1. ask potatodog and pay him less money
2. ask VW and pay many €€€€
You have 2 options:
1 potatodog ,I want to contact him but I can not, I'm from Spain, I would like to send you my picture and I solve the problem
I may help you out with this one too
You still got the old adapted dash with you?
Never exspect any help here in dark cases as such as far as only 0,01% are true professionals
Polo 9N3 GTI CUP Edition
Mitglieder in diesem Forum: 0 Mitglieder und 132 Gäste
