Wollte mal fragen ob man die vorne sitze irgendwie rausnehmen kann und es zuwaschen oder so?
Can't really explain in german, hope you understand what I mean by english. I mean the actual "seat" cover on the front seats, not the back bit.
Lack & Leder
Innen & Aussen
Wieder was dazu gelernt *gg*! Ich glaub den gleichen Fehler wie Sylonien hab ich auch begangenYou should clean textiles always completely, not only spots, to avoid such water-marks.
Thanks for your help and search around for me. I think I understand the idea, but putting the idea to practice might be more difficult when I read through the link you gave me about the "special" screwdriver.Hello!
I searched a little bit in the forum. http://forum.polo9n.info/viewtopic.php? ... e+ausbauen <-- In this Thread I found something!
It's possible to remove the frontseats! You have to remove the four screws in the seatrail. For this screws you need a special bit for your screwdriver. After removing the screws you can put out the seats with the seatrail! If you have sidebags you have to clamp off (I don't know if it's the right word) your battery (first step) and remove the yellow plug for your sidebags on the seat (second step). During your battery and your sidebag is clamped off DO NOT TURN ON your ignition-lock! The result would be a Airbag-failure!
I see - distilled water... good point - should of thought about that beforeStand in meinem Pflege-Heft vom SofaEs gibt halt immer Wasserränder, ausser man nimmt destilliertes Wasser. Wenn man einfach die ganze Fläche von Naht bis Naht nass abreibt, hat man das Phänomen nicht. Klappt bisher gut
I'm not sure but I think that's the only way to remove the seat covers! Perhaps somebody has another idea how to remove the seat covers without put out the whole seat!Thanks for your help and search around for me. I think I understand the idea, but putting the idea to practice might be more difficult when I read through the link you gave me about the "special" screwdriver.Hello!
Is that the only way to remove the seat covers only?
I looked up in a technical dictionary. This kind of screwdriver is called "polygon head"!
That's a kind of "Vielzannschlüssel". The word simply means the thing has a lot of teethHope you understand
As far as I know, in our context the screwdriver has to be the part painted white on the image... but I'm not sure indeed
Sorry ein bißchen altes Thread, aber wollte mal was "clarify'en".Hello!
