Tacho 9n on 9n3
Tacho, MFA, FIS, etc.
Tacho 9n on 9n3
Hi Guys...
can You help me with my question:
it's a problem if i install a 9n tacho with 5500rpm on my polo with 6000rpm??
thank You.
thank You.
Re: Tacho 9n on 9n3
It is not possible to adapt a 9N Tacho in an 9N3
verstorben am: 26.03.2016
Re: Tacho 9n on 9n3
because of this problem or others?
Re: Tacho 9n on 9n3
but I will reflash eeprom so i think there is no problem!Problem is the Immobilizer
Re: Tacho 9n on 9n3
It is more than only one difference in the data record. The software in the MCU is different. If you flash a 9N Tacho with data from 9N3 there will not adapt the Immo-Controller (25)
Re: Tacho 9n on 9n3
so it's impossible to adapt a 9n tacho on 9n3?It is more than only one difference in the data record. The software in the MCU is different. If you flash a 9N Tacho with data from 9N3 there will not adapt the Immo-Controller (25)
Re: Tacho 9n on 9n3
Yes!so it's impossible to adapt a 9n tacho on 9n3?
Re: Tacho 9n on 9n3
and a 9n3 tacho from a 1.9tdi 130cv up to 260 km/h will fit a 9n3 1.9tdi 101 with the Original tacho up to 220km/h? Thank you for your big help!!Yes!so it's impossible to adapt a 9n tacho on 9n3?
Re: Tacho 9n on 9n3
With VCDS it is possible…. Volkswagen dealer not necessarily. Please communicate your VIN and the part number of the Tacho
Re: Tacho 9n on 9n3
i haven't yet...i was asking to understand what i have to buy..With VCDS it is possible…. Volkswagen dealer not necessarily. Please communicate your VIN and the part number of the Tacho
Re: Tacho 9n on 9n3
Can I adapt a tacho with this tool: VAG DASH COM+CAN (can I link the item auction for example?)
without reading and writing an eeprom??
Thanks.
Thanks.
