Tacho 9n on 9n3
Tacho, MFA, FIS, etc.
Kakashi
Tacho 9n on 9n3
Ungelesener Beitragvon Kakashi » 27. Mär 2010, 09:06
Hi Guys...
can You help me with my question:
it's a problem if i install a 9n tacho with 5500rpm on my polo with 6000rpm??
thank You.
potatodog
Re: Tacho 9n on 9n3
Ungelesener Beitragvon potatodog » 27. Mär 2010, 15:34
It is not possible to adapt a 9N Tacho in an 9N3
verstorben am: 26.03.2016 :(
Fahrzeuge: Polo 9N Cricket
Kakashi
Re: Tacho 9n on 9n3
Ungelesener Beitragvon Kakashi » 27. Mär 2010, 17:51
because of this problem or others?
potatodog
Re: Tacho 9n on 9n3
Ungelesener Beitragvon potatodog » 27. Mär 2010, 19:14
Problem is the Immobilizer
Kakashi
Re: Tacho 9n on 9n3
Ungelesener Beitragvon Kakashi » 28. Mär 2010, 11:35
but I will reflash eeprom so i think there is no problem!
potatodog
Re: Tacho 9n on 9n3
Ungelesener Beitragvon potatodog » 28. Mär 2010, 12:03
It is more than only one difference in the data record. The software in the MCU is different. If you flash a 9N Tacho with data from 9N3 there will not adapt the Immo-Controller (25) ;-)
Kakashi
Re: Tacho 9n on 9n3
Ungelesener Beitragvon Kakashi » 28. Mär 2010, 13:29
so it's impossible to adapt a 9n tacho on 9n3?
potatodog
Re: Tacho 9n on 9n3
Ungelesener Beitragvon potatodog » 28. Mär 2010, 22:34
Yes!
Kakashi
Re: Tacho 9n on 9n3
Ungelesener Beitragvon Kakashi » 29. Mär 2010, 11:16
Yes!
and a 9n3 tacho from a 1.9tdi 130cv up to 260 km/h will fit a 9n3 1.9tdi 101 with the Original tacho up to 220km/h? Thank you for your big help!! :anbeten:
potatodog
Re: Tacho 9n on 9n3
Ungelesener Beitragvon potatodog » 29. Mär 2010, 16:15
With VCDS it is possible…. Volkswagen dealer not necessarily. Please communicate your VIN and the part number of the Tacho
Kakashi
Re: Tacho 9n on 9n3
Ungelesener Beitragvon Kakashi » 29. Mär 2010, 23:06
i haven't yet...i was asking to understand what i have to buy..
Kakashi
Re: Tacho 9n on 9n3
Ungelesener Beitragvon Kakashi » 31. Mär 2010, 12:24
Can I adapt a tacho with this tool: VAG DASH COM+CAN (can I link the item auction for example?)
without reading and writing an eeprom??
Thanks.
